Low frequency vibrations are clearly audible from the movie ("wuuuuum").
now i write in all forum that my problem is resolved.
In rcgroup.com the topic brain 2 is disappeared.
Now i have changed 2 points of aileron and elevator as you said.
I have changed:
dumper rubber
shaft
thrust bearings
greased all
and first i have changed biadhesive (did you know that)
now the model gets up right when i push the switch radio.
Now if i want to install one system for return my model at home?brain it does?
Good,
We had already seen the various posts on "RCDreams", "Barone Rosso" and "HeliFreak" forum's.
With the double sided tape you had "masked" the model vibrations transmitted to the flight control unit.
Now with the other replacements you should have "really" reduced the vibrations of the model, which is very good not so much for the flight control unit but for the solidity, robustness and durability of the mechanics of the model, reducing the need for frequent maintenance and repairs.
As far as return to home is concerned, the function is not available (for now) because it is required an added and specific GPS (which however has an additional cost not insignificant).
this is my log after all my interventions.
The vibrations have stabilized on 50-60% on medium.
The high peaks are the moments when i make movements 3d
now i have activate other parameters and memory it is little, if i set 50hz and use all 12 channel i can to register 3 flights from 3 or 4 minutes each one?
Yes, that is correct.
On the other hand, when a problem appears and you want to check what caused it, you normally check what happened on the last flight or at most the penultimate one.
do you want to advise?
If i do one maneuver 3d very hard and my model is next to the ground and i active autolevel/rescue if the model turn on and after goes high the model can crash.
There are two options.
The model upside down i active autolevel/rescue the model goes up without straightens up.
Or other method model goes up for 1 meter and after straightens up and go on up.
In less space save the model.
Now you need sufficient space for turn model (you have to calculate also the main rotor)
In the menù you can one setting for activate autolevel/rescue without straighten up the model and one setting for use it how is set up now.
Consider right or wrong this observation?
Other users have already discussed this many times but without first checking and verifying either.
Rescue takes into account the rotor diameter and tail boom length when activating rescue in inverted flight.
If the model is in inverted flight, negative pitch is given to lift the model off the ground before straightening.
Just go to the "How To" section and watch the "Rescue demonstration" film made at IRCHA. Particularly at minute 1:20 or minute 2:15.
yes you're right.
the model gets up and after turn.
Now watching a video i realized it.
This details while fly they can escape you.
Inutil BRAIN for me is perfect.
In the past you know that i didn't know him?
Why i view the flybarless they sold in combo with model helicopter.
Now in italy all people they buy of elyshop / bizmodel and with my helicopter in the past there was align g pro and now with my model there is microbeast (align trex600l dominator or now align trex650x or othe model trex) all model have microbeast why you not contact align and insert you brain in combo helicopter?
Brain is fantastic but sell it in combo it increasses sales
