Diagnostic Paramete...
Diagnostic Parameter settings not stored
(@rick-vandersloot)
Topic starter   [#354]
It seems when only values are changed in the Parameter Settings Tab that these are not stored in the unit.
I use a windows system and the unit (Brain 2) is connected by a USB cable.
Tried several times and log parameters returned to old (default) settings each time after disconnecting and connecting again.
Only when I also changed a parameter on a other Tab (correction factor I used for this) all the changes on the Parameter settings tab where stored in the unit.
Thank you for the report.
The management of recorded logs, unlike the configuration parameters of the flight controller, is done on an external memory.
Try changing the parameters you want to record immediately after powering up the flight control unit and BEFORE displaying the recorded logs, which load the parameters recorded during recording into the memory, or before using the Real Time playback of the parameters you are currently activating.
You should not experience any problems.
