Additional Item For...
[Solved] Additional Item For Counter Drop-down List
2 Reactions
(@russellr150)
Topic starter   [#381]
Thanks for the ongoing improvements to the Brain/Ikon applications.
Thanks for the opportunity to make suggestions.
I would like to request that an additional item be added to the drop-down list for the optional counters.  I would like to have the option to select "One way bearing".
It would also be good if we had the ability to set a value.  Eg If I had flown with a new item for five hours before checking the counters, it would be good if the user could enter the current value for that item.  At present the only option is to reset it to 0.
I would also like to see the drop down list sorted alphabetically.
Kind regards.
Thank you for your suggestion!
Regarding the addition of ‘One Way Bearing’ in the various languages managed by our three apps and our seven integrations, consider it already done.
For alphabetical sorting, we can only do this for one language. We will do it for English in the three apps.
For the seven integrations, it will take a little longer to change the sending in the current numerical sequence to a different, unordered sequence but keeping the current values currently selected by users.
On the other hand, the possibility of manually editing the hours minutes and seconds is a longer and more complex job, so we will put it on our ‘To Do’ list for now.
Thanks again.
(@russellr150)
Much appreciated.  Many thanks.
(@russellr150)
It is great to see that in Release 3.4.201 the item "One way bearing" has been added to the drop-down list for the optional counters.  The items are now sorted alphabetically.
The manual editing of the values is on the "To Do" list.
Many thanks for making these changes and so quickly.
Thank you, but this section "Requests / Suggestions", was created precisely to collect the most useful and interesting ideas and suggestions from users so that if the requests are feasible and practicable they are implemented in our firmware, app's and Integrations.
The thread of this request is then set as resolved and closed.
