Brain Frsky integra...
[Solved] Brain Frsky integration Lua
(@doverk)
Topic starter   [#361]
Is it possible to get slightly larger font for the integration script and a darker background when in day mode of the radio? It's dificult to see using day mode due to how close the light grey background is to the white font. maybe make the font darker for day mode?
Topic Tags
Thank you for the report.
Can you confirm that you are referring to FrSky transmitters with Ethos operating system and not EdgeTX or OpenTX operating system?
We will analyze the problem and if it cannot be solved through the transmitter operating system we will try to implement alternative solutions in the next versions.
(@doverk)
@customercare  FrSky transmitters with Ethos.
Also when in day mode, the neon green selector should be darker. But generally the larger/bold font woud be greatly appreciated.
(@doverk)
any update on this?
A new version of the Ethos Integration has been released and can be downloaded from our servers using the ‘Download Latest Ethos Integration ...’ command in the "Help" menu of our Windows applications or downloaded from the Downloads section of our website.
In the text file ‘ReleaseNotes’ inside the compressed file:
Version 28 of Ethos_Integration.zip:
- Unified the version number to the other Integrations.
- Added in the loggable parameter ‘SAT Voltage’.
- To improve visibility against the light gray background when Dark Mode is off: reduced the brightness of green and red text and changed labels to black.
