HW telemetry issues...
HW telemetry issues using FrSky F.Port
5 Users
3 Reactions
Topic starter   [#110]
I have an issue with HW-Brain2 telemetry connection.
As soon as I connect the pin 5 in Brain with pin P in my HW80v4 the Brain loses Tx signal and ESC disarms.
When I connect them first and then turn the power on - Brain won't initialize and ESC won't arm - no beeps at all. With the telemetry wire disconnected everything works fine.
I'm trying to make it work with new FrSky ArcherRS receiver, using F.Port connection (F.Port to CH3). I can see the telemetry readings from Brain (all at 0 cause it isn't talking to ESC) the integration LUA script works fine, servos are moving. As long as the telemetry wire isn't connected. Connecting Pin5 (Brain) with pin P (HW80) kills all communication between Rx and Brain
Previously I had it all setup using 2 wires from X4RSB receiver (one for inverted s.bus to SAT1 and second for s.port to CH3). The ESC was then connected to Pin6, as per manual and everything worked fine.
Of course I have selected F.Port in receiver type selection card and Hobbywing telemetry in Brain software.
It seems that Rx-Brain2 talks to each other without any problems, but adding HW ESC to equation ruins the party.
What may be the cause of this?
We have ordered an Archer RS from FrSky european distributor paying this time for a fast shipping within one week (it costs more shipping than the receiver) so, we can test your problem.
Updating:
The other day we received the receiver Archer RS that we had purchased also to be able to respond to this report and to which we soldered a cable on the S.Port inverted pin and power supply.
We were very pleasantly surprised by the telemetric data transmission speed (the update asterisks are constantly on fixed) and the data communication speed with the LUAC application (pages load almost instantly). With this receiver in F.Port mode, Telemetry and Integration are now the fastest compared to all other systems (Jeti, Spektrum, Graupner, Multiplex).
Finally FrSky has managed to realize routines that work perfectly with the Archer RS firmware. It works much better than the firmware for all other FrSky receivers running with the appropriate hardware modifications in F.Port mode.
We used a Brain2 with Firmware 3.3.031, an Archer RS receiver with factory firmware (1.2.0/2.1.2 No firmware updates for this receiver are yet available on FrSky website), an ESC Hobbywing 120A with BEC and a Taranis X9D 2019 transmitter with OpenTX 2.3.10 and ISRM 1.10/2.1.0EU with which we activated the F.Port protocol (not F.Port2) on the receiver.
We receive 10 telemetry parameters without problems and at high update rate:
Temp1, Temp2, VFAS, CURR, RB1C, RB2C, RPM, VFR, RSSI, RxBt.
The loading of the integration pages is very fast.
We suggest to check again both the configuration of the control unit and the ESC <-> Brain2 connection because our tests show that everything works perfectly.
Check also and above all to have not mistakenly loaded in the ESC the firmware specifically dedicated to work only with Vbar control units but the last "Generic" firmware available for the ESC.
Just as an update - RS works very well with Brain using F.Port.
My Brain2 unit was faulty, having PIN5 shorted with CH3 signal pin. After reflowing bad solder joints on pcb it all works well.
(@michel-korthouticloud-com)
Hello, When using the Archer-RS receiver, do you still need the MSH51645? to get full telemetry? or can this receiver wired directly to the Brain2?
thanks
If you use the F.Port protocol you don't need to connect S.Bus signal to the SAT1 port and therefore you don't need the MSH51645 cable.
To connect with the F.Port protocol, just select this protocol in the receiver from the transmitter, then select in the configuration software of our control unit the icon of the F.Port communication protocol of the receiver and follow the scheme that appears after this selection in the next page of the Wizard (only one cable from the receiver to the CH3 connector).
At the receiver you will have to connect the signal cable to the "inverted S.Port" output and obviously the GND and VIN.
If you prefer to connect the old way using both the S.Bus output and the bi-directional S.Port signal, then you will need to connect to both the S.Port and SAT1 connectors of our control unit and you will need the MSH51645 cable for the S.Bus signal connected to SAT1.
(@benno-jurisch)
Hi BrainDEv,
I plugged it in like in the previous post from 21/03/2021 6:08 pm. However, I get all telemetry data from the HB 80 V4 but they are all zero. e.g. TMP1 and TMP2 both zero C°.
If I wire everything according to the old method, the data will also be displayed  example Tmp1 27 C° and Tmp 2 25 C° with a Frsyk Archer RS same software version.
I connected a Frsky Archer RS, GND, VIN Inverted S.PORT to channel 1 into the Brain 2. The Frsky Archer RS has software version 2.1.7 and is bound with ISRM / ACCESS on my HORUS X10S Express, software version OpenTX 2.3.14.
What am I doing wrong.
Thanks very much
Benno
(@benno-jurisch)
Hallo,
soory, it not chanel 1, it is Chanel 3 that i have connectet with the Archer RS
(@benno-jurisch)
my mistake, when transmitting via F.PORT, the telemetry cable from the Hobbywing 80A V4 has to be connected to pin 5 of the Brain2, I still had it connected to pin 6.
Thanks very much
Greetings Benno
(@benno-jurisch)
happy New Year 2022.
Is there a way to use the MSH Brain2, a Hobbywing Platinium 120A and an SM UniSens-E without the MSH51645 adapter cable?
Many Thanks
Benno
Posted by: @benno-jurisch
Many Thanks
Benno
Happy New Year!
This thread is about the F.Port protocol and using the F.Port protocol (or even the new F.Port2) you don't need to use the MSH51645 adapter.
The MSH51645 adapter is only needed if you use the dual S.Port + S.Bus connection.
SM UniSens-E reads the same values that are already read and trasmitted by telemetry ESCs, so it would be just a useless duplication.
To know how to connect the various telemetric ESCs (including your HobbyWing Platinum 120A) just read the page on your ESC in the PDF document "Telemetry" that you can find in the MANUALS section of the various software (Windows, Android, iOS).
In this way the telemetry values transmitted by your ESC will be decoded by the control unit and you will be able to see them in the Flight Logs or in Real Time that you can find in the DIAGNOSTIC section.
As regards the transmission of the values already decoded and present in the flight control unit, towards your telemetry receiver, in the same Telemetry document you can find the page related to your radio/receiver model where you will also find explained the possible configuration of your transmitter in order to correctly display the telemetry data and set the various alarm thresholds.
