cyclic pitch 10 deg...
cyclic pitch 10 degrees and roll/flip rate confusion
(@p-i-engineer)
Topic starter   [#227]
in the wizard when setting cyclic pitch to about 10 degrees. Is that for the fbl algorithm or just a safe number for cyclic pitch?
i have a specter v2 with cyclic pitch set to 10 degrees and my rates on 3d default (420 deg/s). When logging i see i get 340 deg/s for roll and 270 deg/s for flip.
I like the way if flies but would like to understand how to make it flip faster.
i'm curious for a more definitive answer on what to change to tweak this.
do I:
1. increase cyclic pitch more as long as there isn't binding?
or
2. increase cyclic ring in advanced menu?
thank you for the help.
(@p-i-engineer)
did some more digging on helifreak.
i read from you, that 10 degrees is the set reference for the brain.
looking at the software. should i be increasing the "aileron out max" and "elevator out max" to increase achievable rates?
(@p-i-engineer)
aileron/elevator out max is tied directly to cyclic measurement in the wizard. I've increased to 11 degrees, we'll if it helps the issue.
(@jimm-y)
Posted by: @p-i-engineer
Have you tried Feed Forward, when I was working on finding a nice Rates, I then with FF set ie bank2 to 0% FF and bank3 to 99% FF and then tuned FF down from here 99%.
(@p-i-engineer)
Good call. That makes perfect sense. I'll look at logging too to see if I can log set point. I've come to love rotorflight black box for this exact reason.
(@jimm-y)
yea I've been following you on there, let us know how it goes.
(@p-i-engineer)
no setpoint. you could back it out from stick position taking account for expo. But simplest way is going to be to do full stick deflection rolls and flips.
i've learned i really like 300 deg/sec, so it's pretty manageable.
(@jimm-y)
yea what I have with bank 3 @ 300 deg/sec and does continues flips/roll nice though on a separate switch I use pitch expo mixed with pitch pump, gives a nice kinda feel of anti gravity.
