Saving Recorded Log...
Saving Recorded Logs
(@russellr150)
Topic starter   [#77]
I am running version 3.3.006 which is currently the latest version.  In earlier versions, when I saved a recorded log to file, it created a single .csv file.  In version 3.3.006 as well as the .csv file, it also creates a .msh file.  This file consists of a single line of ones and zeros.
Why are two files now created every time I save a log?
Thank you
Hi, Acrow,
The xxxx.msh file that is saved, is used to store which of the 11 parameters had activated the graph display (checkbox at the bottom). This way when you return to view a flight log you don't have to uncheck the parameters you don't want to view again and select the parameters you want to view again.
This file is generated since Flight Logs were introduced (if I remember correctly 3/4 years ago) and not in the last version (3.3.006).
(@russellr150)
Thank you very much for the explanation and for the ongoing development of your products.
