[SOLVED] How to con...
[Solved] [SOLVED] How to connect YGE65LVT to a Brain 2 BT for telemetry
(@serenus)
Topic starter   [#64]
in your description on your webside I can see the telemetrie description but it says nothing how to connect the YGE LVT to the brain2 to get telemetrie and RPM. Can you please let me know how to connect.
Do I have to use the YGE Texy between YGE and the Brain2 ? Where to connect the the red cable (ext.Gov) and the telemetrie calble?
At the end I am using a FrSky r-xsr receiver.
Thanks in advanced for you help. I could not find anything about this problem in the net.
Greetings
Serenus
In the MANUALS section of the apps there are various documents in PDF format among which the first one is "Telemetry" (you can also download the file from the "Downloads" section of our website, but you can also find the documents in the program folder in the windows program menu. So you have three possible options to find the document).
In this document you will find a page for your ESC type and a page for your radio system.
Reading these only two pages you will find all the information and explanations and also simplified connection diagrams.
