Frsky X8R SBUS not ...
Frsky X8R SBUS not working
(@loriepetty)
Topic starter   [#140]
Hi...I'm additionally attempting to arrangement the IKON with FrSKY X8R - SBUS
I can't get any reaction from the ikon - only one red flickering light. the Ikon worked with the DMS2 settings fine. The Ikon likewise looses association with the USB com port with the S-Bus wire connected, that truly has me concerned!
I have reset unit to industrial facility defaults, killed and restarted, set Rx for S-Bus and as yet nothing on the TX yield pages. Several extremely baffling hours I chose to test it with one of my V-Bar regulators to check the S-Bus signal is working and it turns out great. All Tx capacities are working effectively on V-bar.
What type of flight control unit are you using? iKon or iKon2?
Which radio protocol did you select in panel 3 "Receiver selection" of the Wizard?
How did you connect the receiver to the flight control unit?
It would be simpler, easier and faster if you send the file of your current controller configuration.
(In the title of this section it says "Please read Q 01 in the FAQ section before posting here!")
