Brain 1 total unres...
[Solved] Brain 1 total unresponsive after Firmware update to v. 3.2.060
3 Reactions
(@felix_zihlmann)
Topic starter   [#57]
After the update to Firmware v. 3.2.060 my Brain 1 is total unresponsive. The red LED flashes. The throttle output of my TX is at -125%, but the Brain Configuration Interface shows "Input: 87%" on page 12 and the motor wants to run occasionally. The RX protocol is Hott SUMD. Before the update, everything worked fine.
You can try to manually re-load the firmware 3.2.060 (go to “File” menu on top left, select “Manual Firmware Upload …” and select OK).
Please keep us informed
(@felix_zihlmann)
I have already done this several times without any change in the behavior of the Brain 1. I have a Brain 2 too and there this helped to get it going again.
Posted by: @felix_zihlmann
We knew you did.
But did you do it AFTER we wrote to you to do it?
Can you please re-update the firmware NOW ?
Please, please, it's only a matter of a minute!
You asked us for help and we responded after less than three hours (time zone) telling you what to do.
Did you do it?
We want to help you! Help us to help you.
Do you let us know?
Thank you!
andyoleary reacted
(@felix_zihlmann)
I have re-updated the firmware now and the Brain is now working normally.
Thank you very much for the fast help!
andyoleary and BrainDev reacted
