Brain 2 with Spektr...
[Solved] Brain 2 with Spektrum NX8 - Flying Styles
(@andythilo)
Topic starter   [#157]
Hi
I'm setting up my Brain2, never done one before. Think I've sorted most of it. I've configured the endpoints so I get +100/-100% in the transmitter setup and reversed Elevator and Rudder so they're correct.
I've setup my bind button as rescue and assigned Aux2 to the bind switch which is button i. That works I think and in menu 11, with the button normal, it's in setup 1 (default) with no autolevel or rescue enabled. If I press the button it goes to Setup 3 with autolevel and rescue enabled.
However, I can't for the life of me figure out to assign the flying styles to my idle up switch which is B. At the moment if I press my rescue switch it changes between setup 1 and setup 3 in the flying style.
Any ideas? I'm assuming rescue and flying style don't have to be on the same switch?
The possibility to activate the Auto Level functions (with or without Rescue) on one of the three Setups is designed for those who have transmitters/receivers with a limited number of channels (5/6/7).
In your case that you have an 8 channel transmitter, you can use a channel dedicated to this function (EG: channel 8 = channel Aux3 in Spektrum transmitters, to activate Auto Level with or without Rescue), leaving the three setups (channel 7) independent from this feature.
Changing the three setups (for each of the three setups you can select a different flight style so that you can test in flight which flight style you like best) can be done with a switch dedicated for this purpose only, or you can also do it with the same switch you use to change Idle Up and RPM.
By using a dedicated switch other than the Idle Up switch, you have more combinations of Flight Style and RPM available.
andythilo reacted
(@andythilo)
Thanks, got it figured out. Now I can switch flight modes with my idleup switch (no rescue/self level in all modes) and have my bind top button enabled to activate rescue.
