[SOLVED] Wiring frs...
[Solved] [SOLVED] Wiring frsky rx4r to Brain2
 MGU
(@mgu)
Topic starter   [#69]
I was thinking about using a Brain2 + a FrSky rx4r in my Oxy3, but when looking at the documentation I have some doubts if this will even work. The receiver has a 6pin connector which has both sbus and s.port connections. Looking at the brain2 documentation I see only the setup for the "older" frsky receivers. Now my question is it even possible to have a setup with the rx4r WITH telemetry running? Right now I am not really sure how to wire this up since the adapter cable MSH51645 won't work with this setup.
 MGU
(@mgu)
I had another look at this. It looks like the rx4r comes with a wiring harness which already has a correct female servo connector to conntect to CH3 of the Brain (S.Port).
The only thing then missing is the SBUS connection via the SAT1 port. Is it enough to only connect the SBUS out of the reciever  to the MSH51645 which then plugs into SAT1, since I already have ground via S.Port to the receiver from the Brain? This would make the wiring a lot easiert, otherwise I would have to splice the GND from the servo cable or get it from one of the other servo connectors.
Posted by: @mgu
BR
 MGU
(@mgu)
Posted by: @mgu
BR
Thank you very much for the confirmation, this makes the complete setup a lot easier.
