02/03/2021 8:13 am
Hello, I am using ikon2 for a gasser helicopter, with OpenTX integration, the governor sensor is sensing the RPM of the autorotation gear and is connected to GOV port, the question is can I connect a second RPM sensor that is sensing the RPM directly from the engine and connect it to CH6, from the manual I understand that CH6 is only used for logging inside the unit but I want the second rpm value to be transmitted back to my TX, is there a way to do it?
03/03/2021 7:17 pm
Thank you for your report and request.
We had not thought about this feature.
We will try to implement also this new feature in the next firmware version as well.
