help with ikon2 mic...
help with ikon2 micro 180 cfx
(@brandoncouch20)
Topic starter   [#410]
 i am having issue Ikon2 only works when the usb cable is plugged in as soon as i un plug usb i loose control of servos battery is charged and plugged in also. i have tried resetting to factory and starting over with no luck. this is not my only ikon2 i have no issues with my other one.
(@brandoncouch20)
Also it will only go into bind mode with usb power if i check the bind box and use battery it wont bind only after unplugging and plugging back in usb. im useing spectrum dsmx sat
We had already replied to your email in which you said the same thing.
