Hello Team MSH-Electronics,
Recently I changed some of the parameters I wished to log. I also saved the file and then reloaded it off-line to check that the changes had been saved.
After I flew, I checked the logs and the parameters had reverted to the earlier version.
I am running firmware 3.3.031.
Attached is the new mtr file and the old mtr file.
I've used other systems were you had to save changes, screen by screen but I thought changes were written to the connected unit immediately. Have I missed something?
Thanks for any suggestions.
If the problem only happened once and then never happened again, it may have been caused by a momentary glitch in the PC or by a false contact of the USB cable or by a power failure or glitch in the internet connection.
If the problem is repeated, you would need to know exactly what sequences of operations are causing the problem in order to play it back.
If only the parameters to be logged in are changed without any operation before or after the problem continues to occur?
Thanks!
Hello BrainDev,
Thanks for the reply. The only items changed were parameters. The good news is that I know it wasn't a user fault. The random issues are hard to resolve.
