Cannot configure Se...
Cannot configure Servo with Refresh Rate of 666Hz
(@marco)
Topic starter   [#375]
Hi
The Tail Servo AGFRC A35BHM-H has a refresh rate of 666Hz. The maximum in the Brain Configuration Interface is 560Hz. Does this servo not work with brain? Or how I have to configure that?
Thank you
Marco
Servo manufacturers define the frequency at which the position-determining command is repeated (Refresh Frequency) as the absolute maximum frequency beyond which you should absolutely never go to avoid malfunction (otherwise the command would be “truncated” by the next command sent too soon).
In contrast, there is absolutely no problem with using a lower command repetition frequency.
You can therefore use your tail servo with a refresh rate of 560Hz without any problem.
marco reacted
