Wish on Log File Se...
[Solved] Wish on Log File Selection
(@andreas-fassl)
Topic starter   [#102]
Is there a chance to add to the logfile number either the size of the file or the duration of the log ?
This will be of great help.
For this reason "Flight log number" can be easily shortened.
No, with the current system of continuous real time recording of fligth logs and vibrations on a circular writing memory where new values delete and overwrite older data until the power supply is interrupted, what you ask for is not possible.
It would only be possible by doing a complete scan of the logs memory every time the unit is switched on, but this would drastically lengthen the initialisation time of the control unit.
(@andreas-fassl)
Totally agree when we talk about the unit and memory handling.
My idea was more linked to software on PC, not in the unit.
Software on the PC can easily "scan" the memory in background and display the values. To be more precise when I talk about values  - the counter of collected packages, then there is no need to check anything in the memory, but the lines.
We don't understand what you mean.
The flight log memory is not located in the PC but instead it is physically inside the control unit and is managed by the internal firmware of the control unit so it must be the control unit to scan the flight logs memory to measure the size (and then according to the sample rate measure the durations) of each flight log.
The configuration software running on the PC is only an interface of data transmitted and received in real time by the control unit, data that is processed inside the control unit and not by the interface software. The interface software does nothing. It only displays data processed and transmitted by the control unit.
