Ethos integration -...
Ethos integration - character color change?
4 Users
(@luca-ursini)
Topic starter   [#345]
Hi, the red color for selected parameter is almost impossible to see in the sunlight, on black background: is there a way to change it with another color with higher contrast? thanks
(@luca-ursini)
Posted by: @luca-ursini
Any reply will be appreciated, thanks
Good morning,
Compared to various other radio systems (Spektrum, Futaba, Jeti, EdgeTX, OpenTX, Graupner, JR) Ethos is still used on very few units (only 1,854) and this is the first and only request to change one of the colours of the integrations to make it more visible in strong sunlight without having to shade the screen of the transmitter with your body.
It is a request that has already been put on the to-do list and will be done, but it has a lower priority than many other things that are much more urgent and/or requested by a much higher number of users.
(@luca-ursini)
@customercare Ok, I hoped that with some soft configuration I could sort it out myself.  thanks for the reply.
add me to the list
now it's 2/1854 😉
(@doverk)
Me too
Thank you for the reports.
It seems that the problem is starting to be felt by several users.
We will analyze the problem and if it cannot be solved through the transmitter operating system we will try to implement alternative solutions in the next versions.
A new version of the Ethos Integration has been released and can be downloaded from our servers using the ‘Download Latest Ethos Integration ...’ command in the "Help" menu of our Windows applications or downloaded from the Downloads section of our website.
In the text file ‘ReleaseNotes’ inside the compressed file:
Version 28 of Ethos_Integration.zip:
- Unified the version number to the other Integrations.
- Added in the loggable parameter ‘SAT Voltage’.
- To improve visibility against the light gray background when Dark Mode is off: reduced the brightness of green and red text and changed labels to black.
