Hey all
My Brain2 is mounted on the right side of the frame, cables to the back.
Going through the setup wizard there are only configurations available with left side. However doing a closer look on the images might give the intention that in one of the left side images the Brain2 is shown from its bottom, in the other of the left side images from the top side.
Is my interpretation right, that "bottom left, wires back" and the image showing the Brain2 from the bottom side (4 dots which I interprete as screws and no text) really means "bottom right wires back"?
Thank you for your support.
This is the right icon to select.
You can mount the flight controller on the left side of the model by attaching the side of the flight controller with the sticker to the model with double-sided tape, or on the right side of the model by attaching the bottom of the flight controller to the model with double-sided tape.
Either way, absolutely nothing changes from the point of view of operation.
To understand better, you have to imagine the model design as if it were transparent .
😀 cool, thank you for all the explanations.
