Brain2 with Phoenix...
Brain2 with Phoenix Edge telemetry wierd RPM changes
(@michel-korthouticloud-com)
Topic starter   [#169]
I have a Brain2 and a Castle Phoenix EDGE 80 HV ESC
When i connect the Castle Phoenix Edge directly to the brain2, and i leave all telemetry to default all works fine. As soon as i throttle up, the motor start spinning. (i have a simple throttle curve, no governor modes etc)
Then i added the resistor of 10K between the red and Yellow wire, and i enabled in the ESC the option " Link Live Enabled" and set the "auxiliary wire mode" to "RPN out" (not sure why this is is needed, bacause the wire is not connected)
In the Brain2 i changed the telemetry input to also capture the Phoenix edge data.
As soon as i turn on everything i get new telemetry sensors in my transmitter! that seams to be OK, the values are updates etc.
Now the issue:
As soon as i throttle up, the motor start spinning, but it is continuously changing the RPM enormous. See the video.
When i turn of the Link live in the ESC, and i turn of the extra telemetry in the brain2, all is fine again, even with the resistor still in place. But i do not get any telemetry data anymore...
What can i do to solve this?
attached the config of my Brain2
The brain2 is connected to an Archer RS receiver over the FBUS
the video
Hello, is there already an idea what could cause this rpm change?
Posted by: @michel-korthouticloud-com
Can you please try if manually loading firmware 3.4.000 solves the problem and let us know?
Thank you.
Just downgraded the Brain2 to version 3.4.000 and did a quick test. Now all seams to be stable! a nice constant RPM.
The problem is not there when using this older version
Fine
Now you are able to fly with this firmware.
In the meantime we will look for a solution to make sure that in future firmware releases your problem will not occur again.
Thanks, if I need to do some testing with a new release, let me know
