Reset Log Number
(@russellr150)
Topic starter   [#293]
Thanks for continuing to refine and develop the MSH Electronics applications.
With new versions of firmware which change the format of data logging, it is recommended to clear the log memory.  This resets the counter and the next log will be numbered one.
I'd like to see a feature added so that the user can select what the new initial log number will be.  That would allow users to maintain sequential numbering of logs or to reflect the number of flights on their air frame etc.
Thanks for the opportunity to contribute to further enhancements.
Thanks for the suggestion.
We had already thought of associating the numbering of the recorded logs with the flight count of the Counter section, but since there is the possibility of making recordings even with the model on the bench and not in flight, the numbering of the recorded logs can often not match and we abandoned the idea.
Instead, the idea of being able to manually intervene in the numbering of the recorded logs might be the solution to resolve these possible inconsistencies.
(@russellr150)
Thanks for considering.  I'd prefer that the log numbering system is independent of the counter system.  If people wanted to align them, they still could.
Kind Regards
