MSH Brain 2 AutoLev...
[Closed] MSH Brain 2 AutoLevel question
(@keith-joneses)
Topic starter   [#315]
When I have the AutoLevel block checked in either of the Setup modes, the helicopter moves badly sideways to the left, like it's not compensating for transitional drift (translating tendency) but works fine if Auto-Level is not selected.  I can set the helicopter at a 5 degree lean to the right on the ground, select the Setup Mode while on the ground and hover it, and it will hover perfectly.  If I select it in the air, it constantly wants to move left.  Is there a way to adjust it to compensate for that.  I figured before I did a support request, it might just be a simple adjustment in the program I can make.
It is Probable that you did not read the following Sticky post before submitting your first post:
if you are asking for support
flighteng141 reacted
(@keith-joneses)
@customercare. Yes, I read it but before going through the whole support process, I thought I might could just get a simple answer, like, no, there is adjustment in the program, of yes, adjust this but I guess not.  I will gather all the information required in the support process and make a formal support request through the Brain 2 Software.  Grazie
Auto Level function, has an automatic auto tuning system.
For this reason, there are no commands to add positive or negative offsets on the X, Y axes. Any offset would be canceled and overwritten by the auto tuning.
(@keith-joneses)
@customercare Thanks, I will submit a support request, because either the auto tuning process is 5 degrees off for what the helicopter needs or the helicopter is 5 degrees off from what the auto tuning thinks it should be, to maintain its current position before Auto-Level is activated because it does fine in all three modes until Auto-Level is activated.
