I have two Align T-Rex helis which are configured identically, a 600 and a 700 with nitros. After a recent crash, I have rebuilt the 600. It shows the RPMs with Spektrum Back Plate sensor on the Governor Panel in the Brain setup software, but does not display the RPMs on the iX14 Telemetry Display. The 700 works perfectly. I seam to be having trouble binding the SRLX on the 600. I Bind the DSMX satellites ok, but trying to bind the SRLX gives a "Bind Failed" display message but it flashes, and lights up in operation. So I know the Brain is getting the data from the backplate, but the iX14 is not getting the data. Software in Brain is up to date ending in 308.
It would have been much simpler, easier and quicker to give you a more comprehensive answer straight away if you’d sent us the file containing your FCU’s current configuration, as explained here:
https://www.msh-electronics.com/forum/general-discussions/if-you-are-asking-for-support/#post-2210
Regardless of the above, if your Spektrum telemetry receiver isn’t working, it’s normal that you won’t be receiving telemetry readings on your transmitter. In fact, basic satellites do not transmit telemetry data to the ground.
To understand why your telemetry receiver isn’t working, we first need to know which receiver you’re using.
You mention using an SRXL telemetry receiver; therefore, it is likely an older SPM4649T receiver. As we haven’t received the configuration file, we can assume that in panel 3 of the Configuration Wizard, you selected the icon SPM4659T for this receiver.
Have you updated the firmware on your SPM4649T receiver to the latest version released by Spektrum at the time?
If, however, you made a mistake and are using a more recent SRXL2 receiver (the SRXL2 serial communication protocol is completely different from the SRXL serial communication protocol), then you should have selected the ‘Multiprotocol’ icon – the one which, amongst the many serial communication protocols, also includes SRXL2.
As we haven’t received the configuration file, we cannot know what serial protocol icon you selected.
It would also be helpful to know which model of SRXL2 receiver you are using.
Again, have you updated the firmware on your SRXL2 receiver to the latest version released by Spektrum?
When you say that the SRXL receiver isn’t correcly bind and working, what are you basing that on? Have you disconnected the DSMX satellites from the flight controller and, using only the SRXL receiver, are you unable to send any commands to your model? In panel 5 of the Wizard (which we cannot check as we haven’t received the configuration file), is the receiver’s status light green or red? The sliders in Panel 5 – which, when saving the configuration file whilst holding both transmitter sticks, should be at their extremes – are they perhaps stuck in the centre?
Have you read in the instructions that your external SRXL receiver, connected to the CH3 port on the front Power Bus, is not powered if the Power Bus is not powered?
Powering the flight controller via a USB cable connected to the PC supplies power to the flight controller and any satellites connected to the SAT1 and SAT2 side connectors, but it does NOT supply power to the front Power Bus to which the receiver and servos are connected and powered.
If, on the other hand, your SRXL receiver is controlling the model correctly but only the RPM telemetry is not being received by your IX transmitter, we have already documented and reported this issue to Spektrum, which is present in the latest versions of AirWare for their IX series transmitters (the DX and NX transmitters do not have this problem).
IX-series receivers running the latest versions of AirWare receive all telemetry values, which are regularly recorded in the TLM telemetry data files saved on the transmitters; however, on the telemetry screen dedicated to RPM, the values—although received—are not displayed (the RPM values transmitted by the ESCs for electric motors are displayed correctly, however).
My Telemetry Receiver is SPM4651T, 3wire in CH3 of the Brain. I have two other telemetry items; Engine Temp and Receiver Voltage. The Engine RPM is the only one not coming into the iX14. But I know the rpm comes into the Brain because I read the RPMs on Panel 12. I don't have an ESC because this is a Nitro motor, I should have mentioned that. My 700 Nitro((as mentioned in my original post) has exactly the same setup, works fine. The only difference between the two machines is the problem 600 machine has the latest Brain Release of 3.4.308 because I had to change the setup. The 700 has not been updated. I will not connect it to the PC until I solve this issue.
Insofar as the SPM4651T is concerned Spektrum Programmer says "No new software is available at this time."
I have ordered an exact replacement for the SPM4651T and will try swapping it out to eliminate it as the source.
If you feel it necessary, I can send my config file.
I have tried replacing the SRXL2 device and had the same result. I have uploaded the Config file with the sticks positioned at the corners lower and right.
Thank you for the configuration file, which shows a correct setup and from which we can see that you have also connected and activated a Futaba sensor to measure the engine temperature.
As regards the RPM, we can only reiterate what we have already explained:
The latest versions of the Airware firmware for the Spektrum IX series transmitters contain a bug. The RPM data received by the IX transmitters is, in fact, recorded in the transmitters’ TLM telemetry files. However, even though the transmitter receives the information, it does not display it on the RPM telemetry screen. We have reported and documented the issue to Spektrum, and beyond that, there is nothing further we can do. Obviously, the more users who put ‘pressure’ on Spektrum by complaining about the problem, the more Spektrum will strive to resolve it quickly.
As for the other telemetry parameters processed by the flight controller and transmitted (Servo Voltage, QOS: Fades, Frame Losses, Holds, Global Vibrations, Temperature, etc.), they should not suffer from the same issue as the RPM and should be received and displayed by the transmitter as normal.
If the temperature is not being received by the transmitter, it is highly likely that the thermal sensor has not been connected correctly, as explained on page 4 of the ‘Telemetry’ PDF manual; however, the other values should be received correctly.
Otherwise, as we have already mentioned, this would mean that your SRXL2 SPM4651T receiver is not updated with the latest firmware released by Spektrum (2.44).
As I indicated the Spektrum Programmer says "There is no update available for this item." I AM AT 2.44 and have been since the start of this thread. Photographic proof attached.
Further, I took a chance and updated my 700 nitro with your latest firmware version "3.4.308", and now my 700 does NOT report rpm on the telemetry page on the iX14 which it was previously doing fine with the very same ix14. So it is your UPDATE that killed it, not anything to do with Spektrum. So I had proof that your previous reply indicates, but this is not the source of my problem. I had two identically configured machines, one worked and one didn't because I updated your firmware on it after a crash. That has caused my problem, not Spektrum. I am at Airware version 2.02.10 dated December 2025. My PlayStore indicate no update needed. I believe it is your most recent firmware that caused my problem with RPM's. I believe my evidence says "308" has caused this problem, not Spektrum.
Thank you. Jim
Are you saying that when you use your IX14 transmitter with AirWare 2.02.10 (dated December 2025), you fly two different Nitro models?
With one model that has its flight controller updated to the latest firmware version (3.4.308), you do NOT see the RPM, but with the other model, which uses a flight controller that has NOT been updated to the latest version, you do see the RPM?
If so, could you tell us the firmware version of the flight controller that displays the RPMs on your other Nitro model, so that we can carry out some checks?
As a test, have you tried downgrading the firmware on the flight controller that doesn’t display the RPMs?
Thank you.
"As a test, have you tried downgrading the firmware on the flight controller that doesn’t display the RPMs?"
You understand what I have experienced with my two nitro helicopters. The one I updated to "308" lost the RPMs. The one I did not update still had the RPMs. When I did update to test it, the RPMs were gone.
The last time I saw it work was 3.4.186. I tried going back to 3.4.276 (as far back as I can go in the application) and that had no RPMs. So, 3.4.186 from 7/13/2024 was working to give you a place to look. When everything is flying as you like, one does not update software, you just fly.
Thank you for letting us know the firmware version that displays the RPMs on the IX transmitters’ screens.
It is an older version that we will need to retrieve in order to investigate the matter.
@customercare I will appreciate having this feature back. Although it did display only engine RPMs. it did not provide the ability to factor in the gear ratio into the display. You would usually have to divide by 8 to calculate the rotor speed in your head. You should find the ability to display engine rpm in almost any firmware from around 2024 to 2025.
@customercare What you posted for instructions, which you published a few years ago, are very incomplete. At that time I followed the instructions and my RPM displayed on my Telemetry page on the iX14 perfectly. It was when I did a recent update of the firmware for Brain that I lost this ability. Please restore this functionality in a future firmware update.
