Brain2 HD switch
Brain2 HD switch
  RSS
kzfarms
(@kzfarms)
18/02/2019 3:44 pm
 This is my first Brain2 HD and I would like to know which 2 of the three pins to connect the switch to. Can I also connect a generator to channel 2 as a second power supply and not hurt the electronic switch that is in the Brain2 HD?
Member Moderator
18/02/2019 9:46 pm
You can use any two pins of the 3-pin connector.
To be precise, you need to use the center pin and one of the two "external" pins.
(The highest and lowest pins are connected together. Then one of the two "external" pins should be connected to the center pin)
You can also power the Brain2 HD on one of the servo connectors (EG: CH2). In this case, however, the switch will no longer have any effect because the switch only controls the input power on the MPX connector.
Note: if for redundancy you want to power the Brain2 and/or Brain2 HD and/or Mini Brain2 and/or Micro Brain2 from different connectors, the voltage carried by the two connectors must be identical because all grounding/GND pins are connected together and all +V pins are connected together (on HD this happen for +V of MPX connector when switch is open).
kzfarms
(@kzfarms)
18/02/2019 10:55 pm
 Thank you for the fast reply.
Please Login or Register
