									Support - MSH-Electronics Forum				            </title>
            <link>https://www.msh-electronics.com/forum/support/</link>
            <language>en-US</language>
            <lastBuildDate>Sun, 15 Nov 2026 06:27:19 +0000</lastBuildDate>
                        <title>brain 2 bz</title>
                        <link>https://www.msh-electronics.com/forum/support/brain-2-bz/</link>
                        <pubDate>Sun, 01 Nov 2026 21:14:18 +0000</pubDate>
                        <description><![CDATA[hallo liebe kollegen ich möchte mein brain 2 bt mit rp3-h und und tx16s verbinden als regler hab ich den hobbywing v5 platinum 80a kann mir bitte jemand bei der verkabelung helfen vielen dan...]]></description>
                        <content:encoded><![CDATA[<p>hallo liebe kollegen ich möchte mein brain 2 bt mit rp3-h und und tx16s verbinden als regler hab ich den hobbywing v5 platinum 80a kann mir bitte jemand bei der verkabelung helfen vielen dank im voraus franz aus österreich</p>]]></content:encoded>
						                            <category domain="https://www.msh-electronics.com/forum/support/">Support</category>                        <dc:creator>franz.woegerbauer</dc:creator>
                        <guid isPermaLink="true">https://www.msh-electronics.com/forum/support/brain-2-bz/</guid>
                        <title>OMPHobby imply I need to fit their optional mass damper to provide extra vibration isolation... do you agree?</title>
                        <link>https://www.msh-electronics.com/forum/support/omphobby-imply-i-need-to-fit-their-optional-mass-damper-to-provide-extra-vibration-isolation-do-you-agree/</link>
                        <pubDate>Tue, 20 Oct 2026 12:13:58 +0000</pubDate>
                        <description><![CDATA[I have just ordered an OMPHobby M6 helicopter. I notice that in the instructions for the M5, M6 &amp; M7 helis they highlight the option to fit a mass damper to their mounting platform to pr...]]></description>
                        <content:encoded><![CDATA[<p>I have just ordered an OMPHobby M6 helicopter. I notice that in the instructions for the M5, M6 &amp; M7 helis they highlight the option to fit a mass damper to their mounting platform to provide extra vibration isolation for certain flybarless units. The exact text is pasted below-</p>
<p><em>"<strong>The inertial mass damper only needs to be installed with inertial measurement units (gyroscopes/accelerometers) of the ICM-20XXX series.</strong>    </em><em>MPU-6000, Bosch BMI series Gyroscopes, as well as ICM-4XXXX series IMUs do not require the mass damper to be installed."</em></p>
<p>My understanding is that my early Brain2 has the MPU-6000 gyro chip and my more recent spare Brain2 has an ICM-20689 gyro chip.</p>
<p>Q1: In the MSH implementation of the Brain2 do I ever need to fit the optional mass damper to an M6 heli, could you clarify please?</p>
<p>Q2: Also, if I need to fit the extra damper only if I have the later gyro chip, then how can I tell for sure which chip I have?</p>
<p>Best regards, Gareth</p>]]></content:encoded>
						                            <category domain="https://www.msh-electronics.com/forum/support/">Support</category>                        <dc:creator>Gareth Evans</dc:creator>
                        <guid isPermaLink="true">https://www.msh-electronics.com/forum/support/omphobby-imply-i-need-to-fit-their-optional-mass-damper-to-provide-extra-vibration-isolation-do-you-agree/</guid>
                        <title>mah capacity compensation explained with examples</title>
                        <link>https://www.msh-electronics.com/forum/support/mah-capacity-compensation-explained-with-examples/</link>
                        <pubDate>Fri, 04 Sep 2026 01:11:01 +0000</pubDate>
                        <description><![CDATA[I have read and watched many videos and no one seemed to be able to give a simple explanation
very simply
sab Genesis sport 700
hobbywing 260platinum v5 setup with telemetry all works
tr...]]></description>
                        <content:encoded><![CDATA[<p>I have read and watched many videos and no one seemed to be able to give a simple explanation</p>
<p>very simply</p>
<p>sab Genesis sport 700</p>
<p>hobbywing 260platinum v5 setup with telemetry all works</p>
<p>trying to dial in capacity and trying at various setups , normal, id1 and 2</p>
<p>&nbsp;</p>
<p>simply with examples if battery is 5000mah put into setup wizard and you are using 4000 when charging back up what would you put for a correction</p>
<p>tried a few with little difference and sometimes when increasing for 10 to 20 in configuration it actually got worse</p>
<p>&nbsp;</p>
<p>if I understood what this number was doing it may help.</p>
<p>is it a percentage?</p>
<p>can we go both positive and negative?</p>
<p>thank you</p>]]></content:encoded>
						                            <category domain="https://www.msh-electronics.com/forum/support/">Support</category>                        <dc:creator>grantwaldreco</dc:creator>
                        <guid isPermaLink="true">https://www.msh-electronics.com/forum/support/mah-capacity-compensation-explained-with-examples/</guid>
                        <title>Using Spektrum iX14 with SRLX to display RPM data.</title>
                        <link>https://www.msh-electronics.com/forum/support/using-spektrum-ix14-with-srlx-to-display-rpm-data/</link>
                        <pubDate>Tue, 11 Aug 2026 11:27:39 +0000</pubDate>
                        <description><![CDATA[I have two Align T-Rex helis which are configured identically, a 600 and a 700 with nitros.  After a recent crash, I have rebuilt the 600.  It shows the RPMs with Spektrum Back Plate sensor ...]]></description>
                        <content:encoded><![CDATA[<p>I have two Align T-Rex helis which are configured identically, a 600 and a 700 with nitros.  After a recent crash, I have rebuilt the 600.  It shows the RPMs with Spektrum Back Plate sensor on the Governor Panel in the Brain setup software, but does not display the RPMs on the iX14 Telemetry Display.  The 700 works perfectly.  I seam to be having trouble binding the SRLX on the 600.  I Bind the DSMX satellites ok, but trying to bind the SRLX gives a "Bind Failed" display message but it flashes, and lights up in operation.  So I know the Brain is getting the data from the backplate, but the iX14 is not getting the data.  Software in Brain is up to date ending in 308.</p>]]></content:encoded>
						                            <category domain="https://www.msh-electronics.com/forum/support/">Support</category>                        <dc:creator>meowguy</dc:creator>
                        <guid isPermaLink="true">https://www.msh-electronics.com/forum/support/using-spektrum-ix14-with-srlx-to-display-rpm-data/</guid>
                        <title>Motor cuts and Servos jittering during Setup and Testing.</title>
                        <link>https://www.msh-electronics.com/forum/support/motor-cuts-and-servos-jittering-during-setup-and-testing/</link>
                        <pubDate>Thu, 16 Apr 2026 16:05:22 +0000</pubDate>
                        <description><![CDATA[While attempting to set up the Helicopter on the Bench, I am getting random
cut-outs of the Motor, and random, but extreme jittering of all the Servos.The Helicopter is as follows:SAB Kra...]]></description>
                        <content:encoded><![CDATA[<p>While attempting to set up the Helicopter on the Bench, I am getting random</p>
1609
<p>cut-outs of the Motor, and random, but extreme jittering of all the Servos.<br /><br />The Helicopter is as follows:<br />SAB Kraken S 700<br />Graupner MZ-32 Tx and GR-16 Rx<br />KDE 700XF 535 Motor<br />Hobbywing 200A Opto V4.1 brand new, I literally just opened it. I bought it 10 years ago for another project.<br />Graupner HCM860 BB MG x3 - Cyclic<br />Graupner HCM880 BB MG x1 - Tail<br />Rx Battery is Turnigy 2S 2600 MAH direct to Ikon2 HD<br />Flight Batteries are 2x Turnigy 6S 5500 MAH<br /><br />The Ikon2 HD is mounted on the elevated FBL Platform (using the 4 provided Rubber Soft Mounts), and the SAB Manual recommended 2mm of Mounting Tape. I used the two Squares of the MSH provided Tape.<br /><br />ESC Telemetry is showing in Transmitter, via Rx Telemetry output.</p>
<p>Hobbywing SCM Module used between ESC and Ikon2. "P" Side Voltage and Ground on the output of the SCM is supplied by the GOV Port + and - Pins. The Output "P" Wire from the SCM is in Pin 5 of the 4-5-6 Port. Output from Data Port of ESC to SCM provides ESC Voltage and "P" Signal to ESC Input side of SCM.</p>
<p>The GOV Wire, (Orange) from the HW ESC Throttle Wire (4 wire bundle) is in Ikon2 GOV Port, other three Wires (Connector) are in CH-1 for Throttle Control.</p>
<p>The Motor is responding to Governor Settings, which were set at 1800, 1900, and 2000. Motor Temp on the Bench is 138 Deg. ESC Temp is 86 Deg.<br /><br />ESC is in Airplane Mode, Voltage Cutoff and Active Freewheel are Disabled. Startup Power is set to 1. Other settings are either defaults or adjusted as necessary for this setup. <br /><br />I'm beginning to think either the KDE Motor is giving off too many Vibrations, and that there is also possibly an issue with the Hobbywing V4.1 ESC, despite it being on their latest Firmware. I have read about these issues in Helifreak, regarding the 200A Ver 4.0 ESC, but I believe the issues were not fixed in the Ver 4.1 ESC either. Can you confirm either way please, before I spend money for a new Motor and ESC? Something in this setup is giving me fits, and I'm not sure if it's a single point of failure, or multiple issues. Please let me know if you need any other Logs or something specifically done to diagnose this. Thank you very much, in advance.</p>
<p>&nbsp;</p>
<p>**EDIT**  I just re-ran the Test with the Real-Time Analysis, and this is the XML File for that.  None of the Sticks were touched. The only thing I changed during this Test was the Governor Speed, with the IU Switch. The Motor Temp never surpassed 153 Deg F, and the ESC never went over 98 Deg F.</p>
<p>&nbsp;</p>
1610
<p><br />Harry Strain.</p>
1608
<p>&nbsp;</p>]]></content:encoded>
						                            <category domain="https://www.msh-electronics.com/forum/support/">Support</category>                        <dc:creator>cnturion2k</dc:creator>
                        <guid isPermaLink="true">https://www.msh-electronics.com/forum/support/motor-cuts-and-servos-jittering-during-setup-and-testing/</guid>
                        <title>Elevator quick oscillations in forward flight - XLPower 700 V2 WC / Brain2</title>
                        <link>https://www.msh-electronics.com/forum/support/elevator-quick-oscillations-in-forward-flight-xlpower-700-v2-wc-brain2/</link>
                        <pubDate>Thu, 02 Apr 2026 10:09:48 +0000</pubDate>
                        <description><![CDATA[Hi,
I&#039;m facing two issues with my Brain2 on a new build. I fly scale/sport style only (no 3D). The heli has about 15-20 flights so far and these issues have been present since the beginning...]]></description>
                        <content:encoded><![CDATA[<p class="font-claude-response-body break-words whitespace-normal leading-">Hi,</p>
<p class="font-claude-response-body break-words whitespace-normal leading-">I'm facing two issues with my Brain2 on a new build. I fly scale/sport style only (no 3D). The heli has about 15-20 flights so far and these issues have been present since the beginning. All Brain2 parameters are at default except where noted below.</p>
<p class="font-claude-response-body break-words whitespace-normal leading-"><strong>Setup:</strong></p>
<ul class=":mb-0 :mt-1 :gap-1 :pb-1 :pb-1 list-disc flex flex-col gap-1 pl-8 mb-3">
<li class="whitespace-normal break-words pl-2">XLPower Specter 700 V2 – WC Edition</li>
<li class="whitespace-normal break-words pl-2">Main Blades: SAB S701</li>
<li class="whitespace-normal break-words pl-2">Tail Blades: SAB S105</li>
<li class="whitespace-normal break-words pl-2">Motor: XNova Lightning 4525/YY-530KV 10P</li>
<li class="whitespace-normal break-words pl-2">ESC: Hobbywing Platinum Pro 180A HV V5</li>
<li class="whitespace-normal break-words pl-2">Servos: Theta Razor – 3× C1 (cyclic) / 1× T1 (tail)</li>
<li class="whitespace-normal break-words pl-2">RX: RadioMaster RP3-H</li>
<li class="whitespace-normal break-words pl-2">TX: RadioMaster TX16S</li>
<li class="whitespace-normal break-words pl-2">Head speed: 1950 RPM (ESC internal governor)</li>
<li class="whitespace-normal break-words pl-2">Brain2 firmware: 3.4.275</li>
</ul>
<p class="font-claude-response-body break-words whitespace-normal leading-"><strong>Mechanical checks I've done:</strong></p>
<li class="whitespace-normal break-words pl-2">Swashplate is level — pitch measured at multiple rotor positions using the Brain2 Swashplate Setup page (with the software commanding the servos to the zero-pitch position) reads 0° ±0.15°.</li>
<li class="whitespace-normal break-words pl-2">No tracking issues visible in hover — blades are running in the same plane.</li>
<li class="whitespace-normal break-words pl-2">Heli is balanced (nose and tail weigh the same).</li>
<li class="whitespace-normal break-words pl-2">Transmitter is confirmed sending center pulse with stick at neutral.</li>
</ul>
<p class="font-claude-response-body break-words whitespace-normal leading-"><strong>Issue 1 — Constant backward drift in hover:</strong></p>
<p class="font-claude-response-body break-words whitespace-normal leading-">The heli has a persistent tendency to pitch nose-up during hover. It's a small but noticeable drift — after 3–4 seconds of hands-off hover, the heli starts moving backward. This happens regardless of wind direction. I don't experience this behavior on other helis flown at the same location under the same conditions.</p>
<p class="font-claude-response-body break-words whitespace-normal leading-"><strong>Issue 2 — Oscillations in forward flight (main concern):</strong></p>
<p class="font-claude-response-body break-words whitespace-normal leading-">I'm seeing two distinct oscillation behaviors during forward flight:</p>
<p class="font-claude-response-body break-words whitespace-normal leading-"><strong>(a) Slow pitch oscillation ("porpoising"):</strong> During fast forward flight, the heli exhibits a slow, lazy nose up-and-down oscillation, similar to a dolphin swimming. This gets worse with increasing speed. To address this, I reduced both the elevator P-gain and I-gain by 5 points (from 60 to 55). This seems to have resolved the porpoising.</p>
<p class="font-claude-response-body break-words whitespace-normal leading-"><strong>(b) Fast vibration at the tail boom:</strong> During moderate-speed forward flight — for example, coming out of a fast banked turn — the tail end of the heli vibrates rapidly. It's difficult to tell from the ground whether the movement is in the pitch axis (tail moving up and down) or in the yaw axis (tail moving side to side), since the vibrations are quick and the heli is far away. However, the movement appears more likely to be in the pitch axis — as if rapid, small elevator commands were being applied, causing the nose to oscillate up and down and the tail to follow in the opposite direction. This vibration got worse after I lowered the P and I gains. It's worth noting that the flights where it worsened were on a windy day, so that may be a factor, but the wind conditions were nothing unusual for a 700-class heli.</p>
<p class="font-claude-response-body break-words whitespace-normal leading-"><strong>Logs:</strong></p>
<p class="font-claude-response-body break-words whitespace-normal leading-">I'm attaching the flight logs I have. Note that I changed some logged parameters between flights while trying to address the porpoising, so the earlier logs may reflect different gain settings. If it would help, I can perform additional flights this weekend with specific parameters logged — just let me know what you'd like to see.</p>
<p class="font-claude-response-body break-words whitespace-normal leading-">Thanks in advance for the help. undefined</p>
1603
1604
1605
<p class="font-claude-response-body break-words whitespace-normal leading-"> </p>]]></content:encoded>
						                            <category domain="https://www.msh-electronics.com/forum/support/">Support</category>                        <dc:creator>alexborro</dc:creator>
                        <guid isPermaLink="true">https://www.msh-electronics.com/forum/support/elevator-quick-oscillations-in-forward-flight-xlpower-700-v2-wc-brain2/</guid>
                        <title>Cant get any throttle from Ikon2 HD</title>
                        <link>https://www.msh-electronics.com/forum/support/cant-get-any-throttle-from-ikon2-hd/</link>
                        <pubDate>Wed, 11 Mar 2026 21:10:26 +0000</pubDate>
I have a brain 2 HD on a goblin 580 raw
ESC is Castle Creations 120HV, using 6s config on the heli
I am also using Radiomaster 16S Mkii, and have a native 4 in 1 module. I bound the u...]]></description>
                        <content:encoded><![CDATA[<p>Hi,</p>
<p>I have a brain 2 HD on a goblin 580 raw</p>
<p>ESC is Castle Creations 120HV, using 6s config on the heli</p>
<p>I am also using Radiomaster 16S Mkii, and have a native 4 in 1 module. I bound the unit with 2 Spektrum DSMX satellites</p>
<p>I updated the Brain2 ( and my PC app) to latest Software release for unit an app on first boot today</p>
<p>I have verified that the Brain2 bound correctly, as 3 cyclic and rudder servos are functioning as expected when unit is powered up</p>
<p>I have verified that my ESC throttle input cable is correctly plugged into channel 1 on the Brain, and not inverted, wrong pins, etc.</p>
<p>I have verified that I am not on throttle hold</p>
<p>I have verified that the channel monitor is outputting signal from radio perspective.</p>
<p>After the Brain 2 finishes initializing. the swash is responsive, but the ESC LED blinks continuously, indicating either non valid zero signal for off, or is getting no signal at all</p>
<p>In an attempt to verify anything is coning out of the brain2 on throttle, I hooked up a servo to channel 1 and it did not move - indicating to me that perhaps no signal is present on this channel - I also verified that servo worked (also tried disconnecting one of the functioning Cyclic servos and moved it into Channel 1) - both test failed to move servo</p>
<p>I have tried numerous throttle curves including 2 point linear (-100 to 100) - 0 to 100, ramp to 60% etc - nothing works</p>
<p>I have tried setting ESC into calibration mode by powering up heli with throttle stick full forward and also, nothing happens</p>
<p>I have tried moving throttle stick to various positions and leaving for 30+ seconds and nothing works</p>
<p>ESC is behaving as if n throttle signal is coming from Channel 1</p>
<p>I am out of ideas and lost - any help is appreciated</p>
<p>Joe</p>
1601
<p>&nbsp;</p>
						                            <category domain="https://www.msh-electronics.com/forum/support/">Support</category>                        <dc:creator>jfinkel48</dc:creator>
                        <guid isPermaLink="true">https://www.msh-electronics.com/forum/support/cant-get-any-throttle-from-ikon2-hd/</guid>
                        <title>Vibration Log Brain2 Bluetooth</title>
                        <link>https://www.msh-electronics.com/forum/support/vibration-log-brain2-bluetooth/</link>
                        <pubDate>Sun, 01 Feb 2026 22:21:47 +0000</pubDate>
                        <description><![CDATA[Hi, I need help analyzing the vibrations on my helicopter (TREX 700 GASSER). I did a long test flight where I tried various rpms and noticed that the vibrations were lower at 1900 rpm, but t...]]></description>
                        <content:encoded><![CDATA[1586
1587
<p>Hi, I need help analyzing the vibrations on my helicopter (TREX 700 GASSER). I did a long test flight where I tried various rpms and noticed that the vibrations were lower at 1900 rpm, but there were moments where the global vibrations reached 500. Mechanically, the helicopter is fine, and the blades are tracking correctly. Do you have any idea what might be causing the vibrations?<br />Also, during hovering, the helicopter tends to tail down; I can't achieve a steady, stable hover.I've attached the log and current configuration. Thank you</p>]]></content:encoded>
						                            <category domain="https://www.msh-electronics.com/forum/support/">Support</category>                        <dc:creator>Fabio Monaco</dc:creator>
                        <guid isPermaLink="true">https://www.msh-electronics.com/forum/support/vibration-log-brain2-bluetooth/</guid>
                        <title>5 blades head phasing issue</title>
                        <link>https://www.msh-electronics.com/forum/support/5-blades-head-phasing-issue/</link>
                        <pubDate>Mon, 03 Nov 2025 09:08:16 +0000</pubDate>
                        <description><![CDATA[Hello
I have an issue when I try to set virtual phasing on a 5 blades 600 scale heli.
I have set the swashplate follower arm to have pushrods 90° straight down to the swashplate in order t...]]></description>
                        <content:encoded><![CDATA[<p>Hello</p>
<p>I have an issue when I try to set virtual phasing on a 5 blades 600 scale heli.</p>
<p>I have set the swashplate follower arm to have pushrods 90° straight down to the swashplate in order to obtain non mechanical phasing at all.</p>
<p>I have not any mixing between channel in tx.</p>
<p>All the settings in Brain software are properly completed.</p>
<p>I set phasing in the ccpm advanced menu.</p>
<p>Firstly, with reference blade holder parallel to the tail boom, I set phasing value to -60° in order to have no rotation when I move elevator stick forward and backward, and rotation when I move aileron stick left and right. That’s fine.</p>
<p>Secondly, with reference blade holder perpendicular to the tail boom, when I move elevator stick forward and backward, the blade holder rotate, it’s okay, but when I move aileron stick left and right, the blade holder rotate too. That’s the problem. I have to set phasing value to -30° to fix it, but the phasing is now wrong when the blader holder is parallel to the tail boom.</p>
<p>It seems there is somewhere a cross coupling between aileron and elevator, mechanical or electronic. It's very strange because, in step 5, I don't see any coupling between aileron and elevator channel during phasing test.</p>
<p>I don’t understand where the error is ?</p>
<p>Thanks for your help</p>]]></content:encoded>
						                            <category domain="https://www.msh-electronics.com/forum/support/">Support</category>                        <dc:creator>jeanmichelbarbe</dc:creator>
                        <guid isPermaLink="true">https://www.msh-electronics.com/forum/support/5-blades-head-phasing-issue/</guid>
                        <title>Blade 230s</title>
                        <link>https://www.msh-electronics.com/forum/support/blade-230s/</link>
                        <pubDate>Wed, 22 Oct 2025 03:52:34 +0000</pubDate>
                        <description><![CDATA[Hey everyone,
I hope you can help, I have been upgrading a blade 230s with zero luck. The heli works with stock setup but with the Brain 2 I cannot get the main motor to initialize and the ...]]></description>
                        <content:encoded><![CDATA[<p>Hey everyone,</p>
<p>I hope you can help, I have been upgrading a blade 230s with zero luck. The heli works with stock setup but with the Brain 2 I cannot get the main motor to initialize and the tail motor spoils up way too fast. I'm using a NX7e and a receiver that works on another heli. I followed the step by step setup for the folks from Amain hobbies. What am I missing any help would be greatly appreciated. Thanks</p>]]></content:encoded>
						                            <category domain="https://www.msh-electronics.com/forum/support/">Support</category>                        <dc:creator>jlm6160</dc:creator>
                        <guid isPermaLink="true">https://www.msh-electronics.com/forum/support/blade-230s/</guid>
