									Brain Frsky integration Lua - Requests / Suggestions				            </title>
            <link>https://www.msh-electronics.com/forum/requests-suggestions/brain-frsky-integration-lua/</link>
            <lastBuildDate>Sat, 10 Oct 2026 11:28:23 +0000</lastBuildDate>
                        <title>RE: Brain Frsky integration Lua</title>
                        <link>https://www.msh-electronics.com/forum/requests-suggestions/brain-frsky-integration-lua/#post-3417</link>
                        <pubDate>Tue, 03 Dec 2024 07:20:18 +0000</pubDate>
                        <description><![CDATA[A new version of the Ethos Integration has been released and can be downloaded from our servers using the ‘Download Latest Ethos Integration ...’ command in the &quot;Help&quot; menu of our Windows ap...]]></description>
                        <content:encoded><![CDATA[<div class="wpforo-post-content">
<p>A new version of the Ethos Integration has been released and can be downloaded from our servers using the ‘Download Latest Ethos Integration ...’ command in the "Help" menu of our Windows applications or downloaded from the Downloads section of our website.</p>
<p>In the text file ‘ReleaseNotes’ inside the compressed file:</p>
<p>Version 28 of Ethos_Integration.zip:<br />- Unified the version number to the other Integrations.<br />- Added in the loggable parameter ‘SAT Voltage’.<br />- To improve visibility against the light gray background when Dark Mode is off: reduced the brightness of green and red text and changed labels to black.</p>
</div>]]></content:encoded>
						                            <category domain="https://www.msh-electronics.com/forum/requests-suggestions/">Requests / Suggestions</category>                        <dc:creator>BrainDev</dc:creator>
                        <guid isPermaLink="true">https://www.msh-electronics.com/forum/requests-suggestions/brain-frsky-integration-lua/#post-3417</guid>
                        <link>https://www.msh-electronics.com/forum/requests-suggestions/brain-frsky-integration-lua/#post-3400</link>
                        <pubDate>Tue, 05 Nov 2024 16:12:57 +0000</pubDate>
                        <description><![CDATA[any update on this?]]></description>
                        <content:encoded><![CDATA[<p>any update on this?</p>]]></content:encoded>
						                            <category domain="https://www.msh-electronics.com/forum/requests-suggestions/">Requests / Suggestions</category>                        <dc:creator>doverk</dc:creator>
                        <guid isPermaLink="true">https://www.msh-electronics.com/forum/requests-suggestions/brain-frsky-integration-lua/#post-3400</guid>
                        <link>https://www.msh-electronics.com/forum/requests-suggestions/brain-frsky-integration-lua/#post-3354</link>
                        <pubDate>Tue, 13 Aug 2024 22:27:44 +0000</pubDate>
                        <description><![CDATA[@customercare  FrSky transmitters with Ethos.
Also when in day mode, the neon green selector should be darker. But generally the larger/bold font woud be greatly appreciated.]]></description>
                        <content:encoded><![CDATA[<p>@customercare <span> FrSky transmitters with Ethos.</span></p>
<p><span>Also when in day mode, the neon green selector should be darker. But generally the larger/bold font woud be greatly appreciated. </span></p>]]></content:encoded>
                        <guid isPermaLink="true">https://www.msh-electronics.com/forum/requests-suggestions/brain-frsky-integration-lua/#post-3354</guid>
                        <link>https://www.msh-electronics.com/forum/requests-suggestions/brain-frsky-integration-lua/#post-3352</link>
                        <pubDate>Tue, 13 Aug 2024 16:20:16 +0000</pubDate>
                        <description><![CDATA[Thank you for the report.
Can you confirm that you are referring to FrSky transmitters with Ethos operating system and not EdgeTX or OpenTX operating system?
We will analyze the problem an...]]></description>
                        <content:encoded><![CDATA[<p>Thank you for the report.</p>
<p>Can you confirm that you are referring to FrSky transmitters with Ethos operating system and not EdgeTX or OpenTX operating system?</p>
<p>We will analyze the problem and if it cannot be solved through the transmitter operating system we will try to implement alternative solutions in the next versions.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://www.msh-electronics.com/forum/requests-suggestions/brain-frsky-integration-lua/#post-3352</guid>
                        <title>Brain Frsky integration Lua</title>
                        <link>https://www.msh-electronics.com/forum/requests-suggestions/brain-frsky-integration-lua/#post-3350</link>
                        <pubDate>Mon, 12 Aug 2024 23:37:10 +0000</pubDate>
                        <description><![CDATA[Is it possible to get slightly larger font for the integration script and a darker background when in day mode of the radio? It&#039;s dificult to see using day mode due to how close the light gr...]]></description>
                        <content:encoded><![CDATA[<p>Is it possible to get slightly larger font for the integration script and a darker background when in day mode of the radio? It's dificult to see using day mode due to how close the light grey background is to the white font. maybe make the font darker for day mode?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://www.msh-electronics.com/forum/requests-suggestions/brain-frsky-integration-lua/#post-3350</guid>
