									Ability to change playback speed on Vibratons Tab (Diagnostic section) - Requests / Suggestions				            </title>
            <link>https://www.msh-electronics.com/forum/requests-suggestions/ability-to-change-playback-speed-on-vibratons-tab-diagnostic-section/</link>
            <lastBuildDate>Sat, 05 Sep 2026 13:56:33 +0000</lastBuildDate>
                        <title>RE: Ability to change playback speed on Vibratons Tab (Diagnostic section)</title>
                        <link>https://www.msh-electronics.com/forum/requests-suggestions/ability-to-change-playback-speed-on-vibratons-tab-diagnostic-section/#post-3556</link>
                        <pubDate>Thu, 29 May 2025 11:29:19 +0000</pubDate>
                        <description><![CDATA[I was aware of that process, but I do find it challenging to implement - perhaps because I&#039;m getting older. &#x1f923;  It would help to have the scan move at a consistent rate, but if it&#039;s t...]]></description>
                        <content:encoded><![CDATA[<p>I was aware of that process, but I do find it challenging to implement - perhaps because I'm getting older. &#x1f923;  It would help to have the scan move at a consistent rate, but if it's too hard...</p>]]></content:encoded>
						                            <category domain="https://www.msh-electronics.com/forum/requests-suggestions/">Requests / Suggestions</category>                        <dc:creator>PaoloFCantoni</dc:creator>
                        <guid isPermaLink="true">https://www.msh-electronics.com/forum/requests-suggestions/ability-to-change-playback-speed-on-vibratons-tab-diagnostic-section/#post-3556</guid>
                        <link>https://www.msh-electronics.com/forum/requests-suggestions/ability-to-change-playback-speed-on-vibratons-tab-diagnostic-section/#post-3552</link>
                        <pubDate>Thu, 29 May 2025 08:15:06 +0000</pubDate>
                        <description><![CDATA[Of course it is possible!Just go into the Vibrations tab, click on the bottom-right ‘Stop/Pause’ button, and then start moving the time slider down manually with the mouse at whatever speed ...]]></description>
                        <content:encoded><![CDATA[<p>Of course it is possible!<br />Just go into the Vibrations tab, click on the bottom-right ‘Stop/Pause’ button, and then start moving the time slider down manually with the mouse at whatever speed you prefer.</p>]]></content:encoded>
						                            <category domain="https://www.msh-electronics.com/forum/requests-suggestions/">Requests / Suggestions</category>                        <dc:creator>BrainDev</dc:creator>
                        <guid isPermaLink="true">https://www.msh-electronics.com/forum/requests-suggestions/ability-to-change-playback-speed-on-vibratons-tab-diagnostic-section/#post-3552</guid>
                        <title>Ability to change playback speed on Vibratons Tab (Diagnostic section)</title>
                        <link>https://www.msh-electronics.com/forum/requests-suggestions/ability-to-change-playback-speed-on-vibratons-tab-diagnostic-section/#post-3548</link>
                        <pubDate>Thu, 29 May 2025 04:48:40 +0000</pubDate>
                        <description><![CDATA[The ability to observe vibrations from downloaded logging and from saved files is excellent!  But, sometimes the speed of the playback is faster than I can analyse (I&#039;m getting older ;) ).  ...]]></description>
                        <content:encoded><![CDATA[<p>The ability to observe vibrations from downloaded logging and from saved files is excellent!  But, sometimes the speed of the playback is faster than I can analyse (I'm getting older ;) ).  Would it be possible to add a mechanism to change the playback speed for playback other than real-time playback of the vibration data?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://www.msh-electronics.com/forum/requests-suggestions/ability-to-change-playback-speed-on-vibratons-tab-diagnostic-section/#post-3548</guid>
