Hi everyone!
I’m working on my first ever build. I’m using the parts from the tyro 79 and installing them on the reptile cloud 149hd frame.
I have a question about connecting my frsky r-xsr receiver. Since the harness the place of aloe vera planter pot connections that came with the receiver don’t match the connection on the flight controller, can I just pop the pins and pull the wires from the black receiver connector and reinsert them into the white connector that came with the tyro kit? Or how would I go about connecting the r-xsr? I have no idea what I’m doing!
(Hope that makes sense, I included a photo to give you an idea of where I’m at. Thanks for any help!)
Hi, quick question: does the third option ("As Futaba") provide the same functionality (telemetry, openTX integration) as the other two?
No, with the third option (S.Bus only) you cannot have either Integration or telemetry.
Only the S.Bus2 protocol would allow you to be able to transmit telemetry data (but since the telemetry flow of the S.Bus2 protocol is unidirectional, it does not allow you to transmit Integration requests and data from the ground to the model, and therefore Integration would not work), but the S.Bus2 protocol is not handled by FrSky / Smart.Port receivers.
